A question regarding the tier pressures.
I have a 04/330ci, front tire (225/45 ZR 17) and rear (245/40 ZR 17).
What are the correct tire pressures for both front and rear; recently I had a flat tire so I took it to the nearest workshop to fix the problem. They recommend and put 36psi for the front and 43 for the rear tire. In driving it sound smooth, but I am not sure these are the right pressures.
Any recommendation.
Thank you.
Any recommendation.
Thank you.
