A little bit of History
The below is a
Tyrrell P34 - 1st and last 6 wheel in F-1. It was designed by Derek Gardener in 1975. Williams even broke the best lap record with this Tyrrell P34 in 1982 in F-1. FIA then added the 4-Wheel requirement.
Because of the low profile and the aerodynamic shape of the car, 4 10-inch wheels were used as front wheels. This greatly reduced the air drag and increased the tires touching ground surface area. Therefore, better handling.
As far as if the others were product of photoshop. It is up to you to judge.
