welcome aboard Sean.
they should fit without a problem, since the brake calipers are the same on both the 330 sport and zhp. i believe the type 135m and 18 inch upgrade found on coupes are the same size, and offset. 47mm front and 50mm in the rear.
a friend of mine picked up a replica of the type 135m but i can't remember where, and i haven't seen him in a while.. i'll keep you posted when i find out, if you'd like.
